סריקת ערוצי dvb-c
- ramimz
- הודעות: 605
- הצטרף: 10 אוקטובר 2007, 23:00
Re: סריקת ערוצי dvb-c
היי ישראל.
את כל אלה אני סורק..... יכול להיות שיש עוד שחסרים לי ?
- <sat flags="0" name="DVB-C Cable" position="500">
<transponder fec_inner="5" frequency="1102000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1306000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1346000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1354000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1434000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1410000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1442000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1458000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1466000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1474000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1482000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1490000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1498000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1522000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1530000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1538000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1546000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1554000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1562000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1570000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1578000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1586000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1594000" inversion="0" modulation="5" polarization="0" symbol_rate="06510000" system="0" />
<transponder fec_inner="5" frequency="1602000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1602000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1610000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1610000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1618000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1626000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1626000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1634000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1634000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1642000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="5" frequency="1650000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
<transponder fec_inner="5" frequency="1650000" inversion="0" modulation="5" polarization="0" symbol_rate="06890000" system="0" />
<transponder fec_inner="4" frequency="1802000" inversion="0" modulation="5" polarization="0" symbol_rate="05360000" system="0" />
<transponder fec_inner="5" frequency="1000000" inversion="0" modulation="5" polarization="0" symbol_rate="06917000" system="0" />
</sat>
</sat>
DM800se Clone - Amazing unit
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
- ramimz
- הודעות: 605
ורק בשמונה ערוצים הוא מוצא לי ערוצים.
קוד: בחירת הכל
</sat>
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
תודה ישראל.י א כתב:ערוץ MTV Series HD תדר 610אין EPGקוד: בחירת הכל
1_0_19_12D_C_DE_FFFF0000_0_0_0
ביס קוראים לזה רק MTV.
אתם בטוחים שזה אותו אחד?
מישהו יודע איפה יש EPG בעברית לערוצים
PENTHOUSE ו- BEARLY LEGAL?
Pazzini
- הודעות: 284
- הצטרף: 12 אוקטובר 2010, 19:43
דיפ בשום דרך אני לא מצליח להעלות את הערוצים ניסיתי כל מה שאמרת.. אולי תעלה לי את קובץ EPG.DAT שלך תגיד לי איפה להשים אותו ותצרף אליו את קובץ הSETTINGS שאני הראה שאין לי בעיה כלשהי בממיר
תודה רבה
תודה רבה
אחרי עבודה מרובה, הצלחתי, למרות החסימה של הוט, לסדר שיהיה לנו EPG גורף לכמעט כל הערוצים, חוץ מאיזה 5 ערוצים ברוסית.
נשאר לי רק לסדר את ה-SERVICE REF וסיימנו.
אני מוסיף גם EPG להרבה ערוצים של יס וכשאגמור את זה גם שם יהיה יותר מלא.
- ramimz
- הודעות: 605
מישהו יכול לעזור לגבי תדרים ?
על אילו תדרים יושבים ערוץ 10, ערוץ 2, היסטוריה ?
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
- הודעות: 30809
- Has thanked: 9 פעמים
צריך להודות לחברים satbeginner, deepspace מיכאלוש ועוד שכולם ביחד הביאו לתנופה למציאת פתרון לנושא הזה.
- ramimz
- הודעות: 605
תודה רבה לכולם
אבל יש רק בעיה אחת.... אתם רצים רצים רצים
ושוכחים שלפעמים יש כאלה שנתקעים קצת מאחור.
שאלתי כמה שאלות בדף האחרון... ועושה רושם שהן ממש שקופות
אף אחד לא מגיב, למרות שכולם יודעים את התשובות.
מעט לא מכובד.
מעט לא מכובד.
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
מיכאלוש
- הודעות: 199
- הצטרף: 14 אפריל 2013, 22:11
- ramimz
- הודעות: 605
וזה למה ?
אין כאן אף אחד שעובד עם ממיר כמו שלי ?
דרים 800HD סיני עם שלושה טיונרים.
אימיג' של OpenPLi-2.1-HD aguda
מישהו בנוסף על Deep יכול לצרף כאן את הקובץ satellites.xml שלו ?
על איזה אימיג' הפלאג הזה עובד הכי טוב ?
באילו תדרים נמצאים ערוץ 2, 10, והיסטוריה ?
יש עוד הרבה שאלות, אבל צריך להתחיל מאיפה שהוא
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
- ramimz
- הודעות: 605
היי ישראל.
זה גם וגם...... אבל אנסה לפתור בעיה בעיה.
קודם כל מסקרן למה בסריקה נמצאו רק 215 ערוצים.
Deepspace העלה את הקובץ שלו לכאן, ובסריקה שהוא ביצע נמצאו למעלה מ- 800 ערוצים.
אני עם אותו הקובץ הצלחתי למצוא 215 ערוצים.
התדרים שאצלי בשימוש הם:
410
458
466
474
578
586
602
610
הבנתי שערוץ 10 נמצא על תדר 562
וערוץ 2 על תדר 586.
האם גם זה נתון על פי אזור, או שאצל כולם זה מופיע באותם תדרים ?
410
458
466
474
578
586
602
610
וערוץ 2 על תדר 586.
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
תשים פה את הקובץ שלך.
אולי כשערכת את הטקסט נפלו טעויות.
ערוץ 2 ו-10 רשמתי בהערות בתוך הקובץ איזה תדר הם.
- ramimz
- הודעות: 605
קוד: בחירת הכל
</sat>אחת התמונות היפות ביותר שצילמתי
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
- ramimz
- הודעות: 605
משנה ..... אבדוק ואעדכן.
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
- ramimz
- הודעות: 605
לא עזר
התפלגות הערוצים:
תדר 410 נמצאו 7 ערוצים.
תדר 458 נמצאו 38 ערוצים.
תדר 466 נמצאו 38 ערוצים.
תדר 474 נמצאו 22 ערוצים.
תדר 578 נמצאו 31 ערוצים.
תדר 586 נמצאו 30 ערוצים.
תדר 602 נמצאו 23 ערוצים.
תדר 610 נמצאו 26 ערוצים.
סה"כ 215 ערוצים
התפלגות הערוצים:
סה"כ 215 ערוצים
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
- ramimz
- הודעות: 605
קוד: בחירת הכל
<transponder fec_inner="5" frequency="1102000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1306000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1346000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1354000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1410000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1434000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1442000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1458000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1466000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1474000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1482000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1490000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1498000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1530000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1538000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1546000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1554000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1562000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1570000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1578000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1586000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1602000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1610000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1618000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1626000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1634000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1642000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
<transponder fec_inner="5" frequency="1650000" inversion="0" modulation="0" polarization="0" symbol_rate="6890000" system="0" />
</sat>
צלחת 1מ' 5E, 4W, 7W
צלחת 1מ' 5E, 4W, 7W
נסה לשים גם את FEC על 0.
אתה יכול גם לנסות לשים את INVERSION על 1 (אני זוכר שפעם זה פתר לי משהו).
נערך לאחרונה על ידי deepspace ב 12 ינואר 2016, 21:19, נערך פעם 1 בסך הכל.
