FlashWizard 6.3
תוכנה מצוינת לטיפול בטעינת אימגים לכל סוגי הדריבוקסים.
גרסה חדשה למטה
Multidreamboxעדכום לגרסה 6.3
FlashWizard can now address up to 10 dreamboxes, each one with its Name, IP, Login, Passwd, Multiboot used devices, NFS share status, NFS ip, NFS shared directory.
You can easily select the target machine from a drop down list, on any window (Flash and Multiboot), before starting install procedure.
All parameters are set-up on Configuration and Utilities panel.
The connection parameters for all dreamboxes are saved to "fwconnections.ini" file, the file is encrypted and the passwords are hidden while FW is running.
To preserve your connection data, keep that file, and replace it in FlashWizard's folder when you will upgrade to a new program release.
- Channels and Favourites are now saved in different "MyLastSettings" dirs,
depending on which dreambox is selected.
- Fixed recognizing of old .fwz files in multiboot restore.
- Fixed message when trying to install .nfi image on flash (not yet supported)
- FW7020: Revised bootmenu's install/upgrade procedures
* IMAGES INFOWIZARD what is it?
Starting with FW 6.x, a new powerful tool is born: Image InfoWizard
It is a complete editor for backups distribution infos, maybe for images too in the future.
You can add texts and graphics, plus a background picture and a music, plus a sponsored link too.
Texts are in Rich Text Format, you can edit/write them with WordPad (you can run it direct from
InfoWizard tool Window).
The background picture (optional) is a BMP bitmap file.
The background music (optional) can be included from *.mid, *.mp3, *.wav files,
and will be played while saving and restoring backups (both flash and multiboot).
The "sponsored" link (optional) can be input on InfoWizard window, and will show on
your distributed backup, a click will open your browser on linked page.
Image InfoWizard can be used both for flash and multiboot backups, generating a *.FW2 file.
aela
הודעות: 569
הצטרף: 28 אפריל 2004, 21:13
Re: FlashWizard 6.3
שליחה על ידי aela »
אני מנסה לצרוב אימג' לדרים 800hd עם התוכנה הנ"ל אבל בטעינת האימג' קופץ לי חלונית שאומרת לי שזה לא מתאים לדרים 7020
Re: FlashWizard 6.3
תנסה עם dreamup
aela
הודעות: 569
Re: FlashWizard 6.3
שליחה על ידי aela »
יש אפשרות שהדרים יעשה בוט מ usb?
Re: FlashWizard 6.3
דרים 800? לא
aela
הודעות: 569
Re: FlashWizard 6.3
שליחה על ידי aela »
היי הצלחתי להעלות את המכשיר מ USB רק שהטונר ריק .זאת בעיה של דרייבר
אני עדיין מחפש העדכן שאצליח.
