OPENBOX S16HD
bismarck
הודעות: 98
הצטרף: 24 יוני 2006, 21:41
OPENBOX S16HD
שליחה על ידי bismarck »
מעוניין להזמין ממיר OPENBOX S16HD שיש לו אפשרות שיתוף ב470 שקל,ורציתי לקבל חוות דעתלפני ההזמנה.
מפרט הממיר:
FULL HD Support 1080P
with ALI3606 chipset
Linux Operating System
1CA
Support MHEG-5
Cccamd Newcamd MGcamd
pecifications
1. Linux Operating System
2. FULLHD+ PVR +1CA
3. Support MHEG-5, Support HDMI 1.3
4. DVB-S2 Openbox S16 HD PVR
300 MHz MIPS Processor;
Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1;
Fully compliant MPEG-2 MP@HL & MP@ML;
Fully compliant MPEG-1 Layer I & II & III, Dolby Digital Audio(AC3);
SCPC & MCPC receivable from C/Ku band satellites;
multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable/1.2/1.3(USALS) supported)
NIT search supported;
Support MHEG-5;
Support HDMI 1.3;
Support PVR(store in USB disk);
Multimedia files playback(by USB);
Support Electronic Program Guide(EPG) for 7 days;
Teletext and subtitle out through OSD;
Support multi-lingual DVB subtitle and teletext;
Automatic and manual channel scan options;
automatic service scan
channel-change time < 1 second
OSD in many languages and skin-support
Multilingual support on screen menu (OSD): English default, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable;
LED Display
Multiple display mode: 1080p/1080I/720p/570p/576i/480p;
MPEG-2 / H.264 Hardware decoding
Videotext Decoder
Analog audio output: stereo(L+R);
Digital audio output: S/PDIF by coaxial and optical;
S/PDIF Interface for digital bit stream out (AC-3)
YCbCr available;
2 x Scart (RGB, FBAS or S-Video)
Screen format:auto, 4:3, and 16:9;
Upgrade software through USB2.0 port;
Powerful program management function, parent lock;
CA 1x slot
10/100Mbit Ethernet Interface
directly bouquet-lists
Packing:
Gift box:32.5*31.5*8.5CM
1x User Manual
1X Openbox S16 HD PVR satellite receiver
1X Remote Control
yoramile1
הודעות: 6122
הצטרף: 02 ינואר 2004, 20:47
Has thanked: 6 פעמים
Re: OPENBOX S16HD
שליחה על ידי yoramile1 »
כולל שיתוף שווה מאוד |כן|
דרך אגב מתי יצא Support MPEG-5 ?
הודעות: 1068
הצטרף: 17 אוגוסט 2009, 13:03
Re: OPENBOX S16HD
שליחה על ידי drsignal »
המחיר של הממיר הינו כ 67$ עם תמיכה בשיתו@
תבדוק אצל הסינים מה הכי טוב .
יש דגם openbox m3
יש דגם f3 openbox
יש דגם openbox 16
דגם f3 ניתן לחבר כרטיס רשת אלחוטי wifi בחיבור usb (כרטיס של מחשב)
צריך לבדוק איזה צ'יפ ניתמך ויש כרטיסים אלחוטיים שניתן לחבר .
תבדוק מבין הדגמים מה הכי טוב מבחינת ממשק משתמש , מהירות\ איכות חומרה .
יתרון :
f3 בעל מעבד400mhz dualcore .
חסרונות : firmware די דפוק , תוכנה זבלה של הסינים , אין כמו enigma2 .
הכל יחסי , גם אם יש לסינים מעבד חזק וטיונר של sharp אז התוכנה שלהם זבל ואי אפשר להחליף אותה .
אז קורה שליתרון אין בכלל משמעות אם התוכנה שלהם זה לא enigma כמו ב dreambox
aela
הודעות: 569
הצטרף: 28 אפריל 2004, 21:13
Re: OPENBOX S16HD
שליחה על ידי aela »
אני הזמנתי לחמי ממיר SKYBOX F3
עובד ממש טוב תמונה מצויינת הסידור של הערוצים לטעמי יותר טוב מהדרים.
הודעות: 1068
Re: OPENBOX S16HD
הסינים כל הזמן משתכללים .
1.הממיר סה"כ ממיר hd
2. מבחינת שיתוף נאמר עליו שהוא פותח מהר מאוד את הערוצים המוצפנים (בהנחה שיש שרת שיתוף ) ->יתרון .
3. זול
4. תמיכה ב hdmi
5. סרטים יודע לנגן .
6. ניתן לחבר אליו כרטיס אלחוטי רשת אלחוטית .
usb wifi dongle
יש חסרונות אחרים :
1. אחרי תקופה לא תהיה תמיכה של firmware אחרים או אימג'ים
2.תוכנה סגורה בקוד סגור .
3. לא יהיו עדכונים
4. יש שמדווחים שהשלט לא טוב
5. יש שטוענין שתדרים מסויימים עושים בעיות .
אין לי ספק שה openbox יהפך לממיר חזק עוד כמה דורות .
openbox s9,s10,s11,s12,s16 f3 m3
מתקדמים משמעותית מכל דור ודור .
