מנסה להתקין שרת בתוכנה של spark
ולא מצליח.
חברים מבקש את עזרתכם בהתקנה...
התקנת פלגאין בamiko 8900
http://sat-support.org/?a=downloads&dir=23
Unpack the file to a USB device (Flash or HDD) in the root directory (do not put it in some other folder located on the carrier). As a result, to properly install the plugin files must be placed on the support of «X: \ plugin \ var \ (a lot of different folders in the folder var)»
Three. Connect your flash drive into a USB port and wait a minute .... the message with a question: "Install plug-ins or not", choose the item "YES", you will be the scale of the process is waiting for some time. After installing the plugin will automatically reset the satellite receiver. After rebooting again, you are prompted to install plug-ins - select "no", unplug the USB flash drive and delete the folder you created «plugin» on your flash drive differently after each turn the receiver will be offered to install plug-ins, if you will be connected to it, this flash drive.
4.After download satellite receiver, go to the items' Menu »->« Plug in ».
Five. Isolation of the plug and pressing "OK" includes a plug-in, when you turn against him on the right icon changes color from red to green. Green "hot button" remote control allows you to enter the additional settings menu plugin «mcas.stripped», in which you can view information about the card is inserted or edit keys «KeyEdit».
Enabling the plugin «mcas.stripped», enables built-in CA sonax used for the various conditional access card (Irdeto, Viaccess, etc.). To use maps to the menu "Plugins" enable «mcas.stripped», at the same point system Basic settings CONX Conditional Access should be off.
