לכל משתמשי CCCAM 2.3.0 לידיעתכם
mbd
הודעות: 657
הצטרף: 08 דצמבר 2009, 14:48
שליחה על ידי mbd »
הנושא ניבדק ואושר בכמה פורומים.[ניתן לבדיקה בגוגל]
CCCAM 2.3.0 is taking the backdoor crap even a step further.
The lowest scum of the earth, UVADI TEAM, have done it even better this time. Making sure sharing will die for sure if they keep this crap up.
Before I continue, I would urge people with BRAINS and PROGRAMMING SKILLS, to download IDA PRO (torrent) and decompile it for themselfs to find the fu**ing remotely triggered backdoor.
How it works.
When you install CCcam 2.3.0 , nothing special is happening at first, and cccam will check for input activity on the pc or box to make sure nobody is watching. When it finds itself comfortably alone, it will start sending your ENTIRE CCCAM.CFG info to this IP 176.9.242.159 (a rented root server in germany).
Now I recompiled a version so I could trigger the backdoor myself, and TADA, some fu**ing ITALIAN dialup asswipe connected to the server I just set up , IP : 2.32.190.9. So traffic on my card started. THIS THEY CAN NOT HIDE in Cccam, it shows as a CONNECTED CLIENT from one of your clients in cccam.cfg where the dyndns has been removed (still lack of cccam, if dyndns is non-existing) the security feature doesn't work anymore and everybody can connect on that user.
I have 2 words for UVADI TEAM -> YOU SUCK !!!!!!
The future of CCcam is dead thanks to these low life asswipes , just after free sharing and making their own "spidernetwork" on your card.
BLOCK ALL CLIENTS that have 2.3.0 connected to your server as it will still read all connected clients from the server, trough the client !!
latest original CCcam 2.1.3 and 2.1.4 which are secure and don't have this backdoor code.
PS: AGAIN , if you don't want to take the warning for granted, decompile and look for yourself !!!!!!
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
כתובת IP מקלן מגרמניה זה לא מוכיח את יש דלת צדדית
mbd
הודעות: 657
שליחה על ידי mbd »
4 אפשרויות .
1.תלמד אנגלית.
2.תקרא את כל הכתבה.
3.כנס לגוגל לקריאת כל הסיפור.
4.כולם טועים ואתה צודק.
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
יש הרבה עותקים עקב הפרשה הזו
בכל פעם שיש עידכון ל CCAM
הפרשה ניפתח מחדש על דלת אחורית
תעלה את מסכים של CCAM 2.30 לבדיקה
mbd
הודעות: 657
שליחה על ידי mbd »
לא מדובר על כל עידכון מדובר על ה-2.3.0
אף אחד לא אמר את אותם דברים לגבי הגרסאות הקודמות .
כאן עשו ריוורס לקוד עצמו והיגעו לאן שהיגעו.
גם ב-OSCAM היתריעו על הגירסה הזאת .
אבל כל העניין הזה נתון לשיפוטו של כל משתמש באופן אישי.
בהצלחה.
ד.א. כבר מצאו דרך איך לחסום את הדלת האחורית.
damlev
הודעות: 506
הצטרף: 25 אוקטובר 2010, 12:43
שליחה על ידי damlev »
ואיך בדיוק לחסום?
אם זה באמת אייפי אחד בודד,אז ניתן להשתמש ב iptables ולחסום.
לדעתי,יותר פשוט לא להשתמש בגירסה הזו וזהו.אין בה איזה חידוש משמעותי.
הציוד שלי:
- שרת לינוקס Quad core
- דרימבוקס 800
- כרטיס חוקי של סקאי איטליה
mbd
הודעות: 657
שליחה על ידי mbd »
צודק.
אבל אם רוצים לחסום .
netstat + tcpdump
on an linux pc server runing cccam then u'll be fixed
http://hackepedia.org/?title=Tcpdump
aela
הודעות: 569
הצטרף: 28 אפריל 2004, 21:13
שליחה על ידי aela »
מה לגבי גירסה 2.2.1 האם אין איתה את הפיצה הנ"ל ?
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
הכי בטוח CCAM 2.09
למי שלא שלא בוטח בגירסה CCAM 2.30
damlev
הודעות: 506
2.2.1 בסדר גמור.
הציוד שלי:
- דרימבוקס 800
israel6
הודעות: 785
הצטרף: 13 מרץ 2006, 14:23
שליחה על ידי israel6 »
damlev @ 9/1/2012, 10:10 כתב: 2.2.1 בסדר גמור.
מסכים שגירסה 2.2.1 היא גירסה יציבה .
בטח יעבור זמן בטרם אתקין את הגירסה 2.3.0
[מתגלגל]
aela
הודעות: 569
שליחה על ידי aela »
israel6 @ 9/1/2012, 22:15 כתב:
[מתגלגל]
מבחינת יציבות באמת אין מה להגיד
logn
הודעות: 94
הצטרף: 11 מאי 2006, 01:07
שליחה על ידי logn »
אני עם 2.1.4 .
כדאי לעדכן ל 2.2.1 ..?
יש שינוי מהותי ?
Gemini 4.4 / 7e 13e 19e 4w / CubeCafe 200s
damlev
הודעות: 506
ממש לא.תשאר עם זה.
הציוד שלי:
- דרימבוקס 800
yonim20
הודעות: 54
הצטרף: 01 אוגוסט 2006, 14:23
שליחה על ידי yonim20 »
עבדתי כמה ימים עם 2.3.0 הרבה תחנות לא נפתחו לעומת 2.2.1
4w-7w-13e DM800
