DVB Dream 1.5f
להורדה
My Webpage
DvbDream v1.3c
DVBDream v1.7 (trial) is available!
Unicable support added (works only on TBS cards for now)
CI/CAM support for AverMedia (not tested, please confirm)
Support for NetUP devices (Diseqc & CI, not tested)
BDA device error code:14 bug fixed which happens on some devices
Initial installation dialog supports more languages now (Turkish,Greek,Chinese,Arabic,Ukranian,Farsi...)
A few bugs in scheduler fixed
Arabic epg bug fix
Snapshot crash bug fixed
LNB Power Off/On support added (in File menu, works only on TBS and Compro devices for now)
EPG support option added for Israel cable provider HOT.
* If you encounter any problem with EPG text charset, you should pick the correct EPG code page instead of "auto"
* BDA Device options now provides different methods for diseqc (Main Menu->Options->Device Options)
* For unicable, you should select the LNB type as unicable while adding satellites in diseqc dialog
* Unicable and LNB Power Off/On is not supported on all devices. It should work fine on TBS cards with new drivers (these new drivers should be released by TBS in next few days)
* If you are still having problem with diseqc on AverMedia devices, please report. You just need to download latest aver media drivers.
* Kaspersky Antivirus is not recommended since it could be the culprit responsible for des.dll errors due to some false virus alarms / heuristic scan.
dvbdreamsetup_v17
Arabic epg bug fix
dvbdreamsetup_v17
"Samsung QE55Q80T 4K QLED 55
Zgemma h7s
Vu+ Ultimo 4K
Vu+ Uno HD
TeVii S472 DVB-S2 PCIe
Zgemma h7s
Vu+ Ultimo 4K
Vu+ Uno HD
Re: DvbDream v1.3c
DVB Dream : v2.4b is available !
DVB Viewer Application
v2.4b (30.06.2013) What's New
Fix for a minor streaming bug
MIS substreams are listed automatically in manual scan dialog (tested on TBS 6925)
* To test MIS in Europe, 13E Hotbird 11432 V 27500 is recommended, transponder seems to have PLS root code 8 with sub stream IDs 1 and 2
Re: DvbDream v1.3c
DVB Dream: v2.7.2 is available!
DVB TV Viewer Application
v2.7.2 (01 August 2015) What's New • ATSC support was not working very well, fixed, now tested with TBS devices, seems to work fine.
• Duplicate packets issue on TS recording fixed
• Duplicate packets issue on streaming with PAT Override fixed
• EPG Plus was not displaying radio channels, fixed
• Problem with multiple stream (MIS) entries of frequency list INI files fixed. Check Hotbird ini file for example.
• Added support for TBS 6704 ATSC card
Re: DvbDream v1.3c
DVB Dream: v2.8.1 is available!
v2.8.1 (18 January 2016) What's New
VC runtime problem on older Windows versions fixed
Occasional startup file I/O eurekalog message fixed
