ACT_095_E2_usb version
- dudutr
- הודעות: 1440
חדש מACT
Tideglo release 095 changelog:
- back to STLinux 2.2 because of some audio bugs on STLinux 2.3: when i will fix it, we will go again on stlinux 2.3
- added wmv file player
- added multi descrambling feature: i tested it only with incubusCamd 0.99 wich fully supports multidescrambling
for e2 (previous version don't work, and i don't know if other softcams works or not, just test them)
- fixed some memory crash on h264 channels
- fixed remote controller buttons with teletext activated
- fixed DVDPlayer crash
- DVDPlayer buttons are now better showed than before
- supported DTS audio on mkv files
- other MediaPlayer fixes
- updated greek language
- updated bulgarian language
- added samba (not started by default, you have to add it on the rcS_user.sh if you need it)
- added cp2101 external card reader drivers (load it in rcS_user.sh if you need it: /lib/modules/cp2101.ko)
- added ralink rt2870 wireless chipset drivers (load them in rcS_user.sh if you need it: /lib/modules/rt2870sta.ko)
- added Freesat EPG support
- by default the sci-ng driver (pacco's 1.4 version) is loaded at enigma2's boot: this is a temporary option, i built a
sc driver but still getting many memory errors, i don't know when it will be full ready
- update Enigma2 CVS to 02/05/2010
- enabled again PIP function, watching 2 channels on PIP will make slow live channels playing, so it does not work at 100%
ACT_095 changelog:
reworked ACTpanel again(now it look more like a panel)
ACT blue panel can be started now by blue button
updated ACT panel with more options like:
mountmanager panel
sambaserver panel
openvpn panel:can be started by start and stop script(not tested!!
reworked,modified and updated emumanager+ ACT extra v2.0:
added oscam and incubus v0.99
removed extention button from emumanager
1x button red=extention
2x red button=emumanager
emumanager can be found also in act panel
new scriptstarter(removed non useable script)
added epg importer
set Glamour_X-Infinity skin as default
add skin DMConcinnity-HD
added own addon server for plugins,skin,emu
Download Links :
Cuberevo / IPBox 9000 HD
http://www2.hostinoo.com/ffe4go1scym...sb.tar.gz.html
Cuberevo-mini / IPBox 900 HD
http://www2.hostinoo.com/vs2unyks6ezk ... 5v2_E2_900_usb.tar.gz.htm
Cuverevo 3000 / IPBox 910 HD
http://www2.hostinoo.com/hioaudnhu52z ... 5v2_E2_910_usb.tar.gz.htm
Cuberevo 250 / IPBox 91 HD
http://www2.hostinoo.com/9j0b8di1vfy3 ... 95v2_E2_91_usb.tar.gz.htm
Best Regards...
ACT_095 changelog:
mountmanager panel
sambaserver panel
added epg importer
Download Links :
Best Regards...
DM 800HD GP3
1.10--10E-7E-4.8E
1.20--42E
1.10--10E-7E-4.8E
1.20--42E
- הודעות: 1000
- הצטרף: 12 מאי 2007, 21:51
- dudutr
- הודעות: 1440
- הודעות: 1000
- dudutr
- הודעות: 1440
- הודעות: 1000
ונניח והחלטתי להשתמש, אני חייב להעיף את האימג' שיש לי צרוב על הממיר לטובת אימג' שמאפשר את זה ? בלאגן..dudutr @ 7/5/2010, 13:08 כתב: USB הכוונה שהאימג' עולה גם מדיסק קשיח
שמחולק למחיצות, מחיצה אחת של 2 ג'יגה לאימג'
ושאר הדיסק להקלטות
או USB של 32 ג'יגה
2 לאימג' ו30 להקלטות
- dudutr
- הודעות: 1440
לא מעיפים שום אימג'
יש גם אחד צרוב בממיר
וגם אחד שעולה מUSB
בהדלקה של הממיר אתה בוחר עם מה לעלות
(אתה צריך להתקין U-Boot V. 1.3.3
Multi-Boot Config
בממיר,אחרי התקנת שני הקבצים האלה
בהדלקה של הממיר אתה לוחץ 3 בשלט אם אתה רוצה שיעלה האימג' מהממיר
או 5 אם אתה רוצה שיעלה האימג' מהUSB)
וגם אחד שעולה מUSB
Multi-Boot Config
DM 800HD GP3
1.10--10E-7E-4.8E
1.20--42E
1.10--10E-7E-4.8E
1.20--42E
- הודעות: 1000
הבנתיdudutr @ 7/5/2010, 21:02 כתב: לא מעיפים שום אימג'
וגם אחד שעולה מUSB
Multi-Boot Config
תודה:)
תוכל להפנות אותי להסבר על העלאת התיקיות האלה ל-USB כדי להעלות את הממיר? מצאתי מלא הסברים, כולל אלה שהבאת ואני לא מבין מה שייך למה. תודה שוב!
- dudutr
- הודעות: 1440
http://www.sat-israel.com/Forums/index. ... opic=36589
http://www.sat-israel.com/Forums/index. ... opic=36414
DM 800HD GP3
1.10--10E-7E-4.8E
1.20--42E
1.10--10E-7E-4.8E
1.20--42E
- הודעות: 1000
