SIFTeam enigma2 extreme edition *beta5b*
This is a beta version.. and it still have MANY bugs! So, use it at your own risk!
If you have any problems please post the bug... we read it and, if it's a real bug, we put it in our todo list for next release.
Features:
- based on Tideglo nightly build 060
- a standard rc init system with runlevel support
- flash and usb versions available
- integrated multiboot config for bootloader. You can manage mboot options directly from remote controller
- tool for uboot management (console)
- standard ipkg system for packaging management (console and osd)
- emulators and card servers management and supervision (console and osd)
- swap space management (osd)
- daemons management (osd)
- network scan and mount (osd)
- disk manager for format/check/mounts disks and partition (osd)
It work througt device model and serial so it keep your mount point even if you change your devices order
- crossepg preinstalled
- mediaplayer preinstalled
- playerdvd preinstalled
- crond preinstalled (start/stop in daemons)
- dropbear preinstalled (start/stop in daemons)
- httpd preinstalled (start/stop in daemons)
- inadyn installable from repository (start/stop/configure in daemons)
- openvpn installable from repository (start/stop in daemons)
- pcscd preinstalled (start/stop in daemons)
- samba installable from repository (start/stop/configure in daemons)
- syslog preinstalled (start/stop in daemons)
- telnetd preintalled (start/stop in daemons)
- vsftpd preinstalled (start/stop in daemons)
- extended busybox commands set
- online repository with many others packages (plugins, skins, spinners, etc. etc.)
- sysctl support in kernel
- kernel printk enabled throught dmesg
Known bugs:
- probabilly, after a deep standby/reboot/restart gui, you find a new crashlog on your hdd
- after a plugin installation or skinner installation you have to reboot enigma2
- if you find your daemon list or your cardservers list not right updated after an emu/cs installation/uninstallation you have to completely reboot your box
- some missing elements in skin_default folder.. update it throught addons
Some interesting utilities:
cuberevo:~# cs
SIFTeam card server manager utility
usage:
cs list
cs start [emu_number]
cs stop
cs restart
cuberevo:~# emu
SIFTeam emu manager utility
usage:
emu list
emu start [emu_number]
emu stop
emu restart
emu ecminfo
cuberevo:~# uboot
SIFTeam uboot menu editor
Usage:
uboot show
uboot set [menu_id] [label] [image] [type] [arg]
uboot net [ipaddr] [netmask] [gateway] [serverip]
Options:
menu_id number from 1 to 9 (the key in your remote)
label menu description (will be print on cuberevo display at boot)
image 'enigma2' or 'dgs' or 'enigma2_debug' or 'dgs_debug'
type 'flash' or 'usb' or 'disk' or 'nfs'
arg depend from type:
flash no argument is required
usb [device]
disk [device]
nfs [nfs_root]
Examples:
# add dgs flash to button 1
uboot set 1 "DGS FLASH" dgs flash
# add enigma2 flash to button 2
uboot set 2 "ENIGMA2 FLASH" enigma2 flash
# add enigma2 usb to button 3
uboot set 3 "ENIGMA2 USB" enigma2 usb sdb1
# add enigma2 disk to button 4
uboot set 4 "ENIGMA2 HDD" enigma2 disk sda1
# add enigma2 nfs to button 5
uboot set 5 "ENIGMA2 NFS" enigma2 nfs /home/9000hd
# set ip address in uboot
uboot net 192.168.0.6 255.255.255.0 192.168.0.1 192.168.0.3
Many thanks to all developers and betatesters:
Skaman
Tideglo
Ngc1927
Nikolasi
IPbox2008
Katapip
frog68
Theseven
Morpheus883
Genge
U_Killer_Bestia
DOWNLOAD FIRMWARES USB AND FLASH VERSION HERE!!!!
in this link some e*u example
codice:
http://www.mediafire.com/?znezandnnty
1)put .ipk file into /tmp with your ftp client
2)open telnet session
3)from telnet write cd /
3)cd tmp
4)ipkg install filename.ipk
for example
ipkg install newcs167_167-r1_sh4.ipk
that's all
ובכן, למרות שמדובר בגרסת בטא, אני חייב לציין כי מדובר כנראה בגרסה ממש משופרת וממש איכותית לעומת האחרות.
יש כמה בעיות עיקריות של האימולטורים שצריך בינתיים להריץ אותם ידני כולל טעינה שלהם בפעם ראשונה.
הסריקה עובדת בסדר, וגם השיפור של ה MOOUT וכמן כן SIF שופר, כולל מערכת לזיהוי רשתות דרך הממיר, מה שחוסך זמן להגדיר.
בכל מקרה עושה רושם שהגרסה המלאה בהחלט תהווה שיפור משמעותי לעומת האחרות.
יש למה לצפות.
