דגם כרטיס
http://www.stradis.com/hdm500-block.html
HDM500 High Definition MPEG-2 Video Decoder
With a proven history of high quality output, versatility and performance, Stradis has long been the standard-definition MPEG decoder of choice for applications requiring true broadcast quality. Now the new HDM500 High-Definition MPEG-2 Decoder delivers comparable performance in applications requiring High-Definition.
Easy Integration. The Stradis Application Programming interface (API) makes intergrating the HDM500 into video systems fast and easy, and gives applications complete control over all HDM500 functions. The API supports multiple HDM500 decoders in a single computer with synchronized playback across all cards.
Professional Performance. The Stradis HDM500 High-Definition MPEG-2 Decoder decodes MP@HL (4:2:0) video at up to 80 Mbps. It provides continuous, frame-accurate, seamless back-to-back playback of all standard MPEG-2 streams. All popular ATSC-compliant formats are supported: 1920x1080i, 1280x720p, 720x576p, 720x576i, 720x480p and 720x480i.
HDM500 applications include playback from disk for server applications and real-time decoding from a satellite or terrestrial network.
Multiple Video Outputs. The HDM500 High-Definition MPEG-2 Decoder has three video outputs for maximum flexibility. Use the High-Definition Serial Digital Interface (SMPTE 292M) video output and the Digital Visual Interface (DVI) or the analog RGB (or YPbPr) output. It can also display the video image on the computer's VGA monitor (in lower resolution to conserve PCI bus bandwidth).
Available Soon!
מידע על הכרטיס
With the HDM500, your MPEG video application can offer:
Continuous, seamless back-to-back playback of multiple MPEG streams (which may be in different formats: Transport, Program, System or Elementary streams) in all popular ATSC-compliant formats including 1920x1080i, 1280x720p, 720x576p, 720x576i, 720x480p and 720x480i
High-quality conversion of source video to selected display format. Lock the output to one format and all outputs will be in that format, regardless of the source format
Frame-accurate, synchronized playback across multiple decoders
High-speed, random access and display of any I-Frame in an MPEG file for variable speed reverse and forward play, plus seamless switching to any I-frame of another stream
PCR-based clock recovery for 24/7/365 real-time stream reception for continuous decoding of streams received from any common delivery mechanism, including satellite, LAN, and ATM networks
Complete control over all HDM500 functions via the API for Microsoft Windows NT, Windows 2000, and Windows XP. Applications can access the API via a C interface or by using the __stdcall calling convention
API compatibility with all Stradis SDM series standard-definition MPEG Decoders
Additional features for professional MPEG decoding and output:
Still picture display from bit-map files with transition effects and simultaneous audio playback for "slide shows"
True-color graphics over video or still pictures with keying or indexed color with blending
Digital control of video saturation, brightness, contrast, and gamma
Genlock (external framelock synchronization) input
Hardware Audio/Video synchronization
High-Definition Serial Digital Interface (SMPTE 292M) video output with 12 channels of embedded audio
6 AES3 digital audio outputs, may be used as 12 discrete audio channels or 4 may be used as IEC 61937/SMPTE 337M-2000 digital audio outputs to Dolby Digital® (AC-3) or MPEG Multichannel® audio decoders
One pair of unbalanced analog audio outputs for monitoring
Machine Control via remote connector (9-Pin, RS-422A) can be configured as either "Controller" or "Device"
Linear Time Code (LTC) output based on stream time codes or synthesized by the API
Letterbox and pan-and-scan options for displaying 16:9 images on a 4:3 display
Support for extraction of EIA 608 / EIA 708 closed captions with captions inserted into HD-SDI in accordance with SMPTE 334M
API provides three interface levels: RateBuffer, Demux, and File
DirectShow® filters for compressed data input to the Stradis decoder
SMPTE 302M-2002 support for uncompressed digital audio in the Transport, Program, and System streams
Wave file playback and raw PCM audio playback
Audio "voice-over" capability allows the application to replace the audio from the main multiplexed stream with another audio stream
Virtual streams based on a single, repeated I-Frame that can be seamlessly played back-to-back with other MPEG streams
Decryption function for file-based decryption using Stradis-supplied or user-definable algorithms
Video capture interface for capturing decoded video output in lower resolution and placing it into PC memory
Video image can be displayed on the computer's VGA monitor in lower resolution to conserve PCI bus bandwidth
Stradis HDM500 Decoder Operation Highlights:
All decoding takes place in hardware
12-bit Video D/A, 2x oversampled
Decodes MPEG audio (up to eight output channels) in parallel with MPEG video
Supports SMPTE 302M-2002 uncompressed audio (up to 12 channels)
IEC 61937/SMPTE 337M-2000 compressed digital audio output of AC-3 - ATSC A/52 on up to four AES3 outputs
VCXO with clock recovery for streams received by satellite, LAN, ATM or any transport delivery mechanism
Serial Digital Interface (SMPTE 292M or SMPTE259M-C) video output with up to 12 channels of embedded audio, plus DVI and analog RGB (or YPbPr) outputs
פרטים
Stradis, Inc.
1800 Century Blvd., NE Suite 1225
Atlanta, GA 30345-3218 USA
1-404-320-0110
1-404-320-3132 fax
כרטיסב לויוני אשר תומך HD
כרטיס לויני
תמונת כרטיס לויני
מי שהיה מוזמן לרכוש באתר
