חדשות CAS 2
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
חדשות CAS 2
שליחה על ידי m8m8 »
A new powerfull add-on for Cas Interface 2 is coming, beta testers will
receive it next week.
What's the features?
- Smartcard programming 30% faster than Infinity. Supports all the
Smartcard Atmel and PIC based. User friendly interface. Very simple to use
with Smartcard's images supported.
- Smartmouse/Phoenix programmer throught Rs-232. Oscillator @
3,579/3,68/6,00 Mhz. Furthermore it's possible to set the wanted frequency for
unlooping functions. This is one of the hidden features of the Cas
Interface 2.
- Titanium Card Programming is supported 100% via USB. It doesn't
damage the Smartcard at all. 100% signals are controlled by the powerfull
Cas 2 Main Processor.
MORE Unlooper for damaged Titanium Cards. It restores the ATR on most
of the tested cards (No warranty is given to this functionality, it
depends on the OS inside).
- Slow down Circuit for Extreme receivers integrated.
- X-Cam programming through Dummy Card (An adapted Fun Card PCB can be
used). It's possible to program the X-Cam directly throught the USB
port or using the Rs-232 and the X-Cam official software. The first X-Cam
programmer through USB port.
- No more Cable adapting the powerful Xilinx CPLD will switch correctly
all the pins in the 20 Pin connector.
Coming next... Soon...
- Dragon Cam programming (coming soon). We are waiting for Dream
Multimedia to give us some information.
- Dragon Cam Loader Card repaired (coming soon). Will allow you to fix
damaged Gragon Cam Loader Cards.
Other interesting features are gonna be supported very soon.
We took this time to make the things working as best as possible.
Thank you for your patience but we totally redesigned the board to give
the programmer the above functionalities. All this delay will be
re-paid by a wonderfull and not expensive Add-On. All nags about delays are
unuseful.
NEW "DYNAMITE" SMARTCARD PROGRAMMER IS ALSO COMING SOON. STAY TUNED.
IT'S GONNA BE ONE OF THE BEST SMARTCARD PROGRAMMER ON THE MARKET
EVER!!!
משה גמ
הודעות: 1242
הצטרף: 23 דצמבר 2003, 00:44
מיקום: חיפה
הנה התרגום להודעה של אמ 8
שליחה על ידי משה גמ »
powerfull הוספה-על חדש עבור Cas Interface 2 מגיע, בוחני ביתא
קבל אותו שבוע הבא.
מה התכונות?
- Smartcard תכנות 30% יותר מהירות מאינסוף. תומך כל הה
Smartcard Atmel ומבוסס תמונה. משתמש ממשק ידידותי. פשוט מאוד להשתמש
עם Smartcard נתמך תמונות.
- Smartmouse/פניקס throught Rs -232. מתנד מתכמת @a
3,579/3,68/6,00 Mhz. נוסף על כן אפשרי של זה לקבוע את הנירצה תדירות עבור
יצירת לולאה מתפקדת. זה אחת מההסתירו תכונות מהCas
ממשק 2.
- Titanium תכנות כרטיס נתמך 100% דרך USB. זה לא
הזק את הSmartcard בכל ה. 100% אות נשלטות על ידי הpowerfull
Cas 2 מעבד ראשי.
יותר לולאה עבור הזיקה Titanium Cards. זה שחזור הATR הפעל רוב
מהכרטיסים (בדוקים מס. אחריות נתנות לתפקודיות אלו, זה
סומך על הOS פנימי).
- לאט למטה מעגל עבור הצדים המקבלים קיצונים ממוזגים.
- X-Cam תכנות דרך כרטיס (זיוף מסוגל כיף כרטיס PCB נכול להיות
השתמש). אפשרי של זה לתוכנית הX-Cam ישיר throught הUSB
יציאה או משתמשת את הRs -232 והX-Cam תוכנה רשמית. הX-Cam ראשון
לגמור עם מתכמת USB יציאה.
- לא יותר כבל מסגל את הXilinx CPLD יחליף כהלכה חזק
כל ההסיכות ב 20 מחבר סיכות.
הבא הבא... בקרוב...
- פיקת דרקון תכנות (בקרוב הבא ). אנחנו ממתינים עבור חלום
מולטימדיה לנתון לנו כמה מידע.
- פיקת דרקון טוענת כרטיס תיקן (בקרוב הבא ). תאפשר לך לתקן
הזיק Gragon Cam Loader Cards.
תכונות מעניינות אחרות gonna נתמך בקרוב מאוד.
אנחנו לקחנו זמן זה לעשות את הדברים עבדו הכי טוב שאפשרי.
תודה לך עבור סבלנות אבל אנחנו redesigned לגמרי שלך הלוח לנתון
ההמתכמות המעל תפקודיות. כל ההשהיה זאת
משולם-מחדש ע על ידי wonderfull ולא הוספה-על. יקר כל הלהציקים על השהיה
שימושי.
"דינמיט " SMARTCARD PROGRAMMER IS ALSO COMING SOON חדש. השאר מכוונן.
