חדשות לגבי HUMAX 5400
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
גירסה עדכנית לגבי HUMAX 5400
עובד ללא כרטיס
יש גם שיטוף כרטיסים ניסויני
ToH 3.2 with EMU 1.2 (by HoT)
Following CAS-systems become presently emuliert:
- IRDETO/BC - SECA with - SECA2 for Ident 64 - VIA - NAGRA with AU - CONAX
To the installation would note please following steps:
The HDF-file HoTEmu****.HDF consists of the basis firmware and the ToH-modules, like also the Emu. The
HDF-file is balanced out like usually with the download tool WDN40AK +.
After the HDF was loaded in the Humax, also the EmuKey-filed in the Humax must. Used to this 9500 EMU Ed23.exe". Attention, the Humi must not be turned on hiefür, therefore in the Standby. For letter would use the Button "Write". Please would test written arrived is in that 1st once with "Read", whether that
Key-filed also in the Humax. Under WIN2000, it seems to give there problems. After the store, one should bring the Humax an once in the Standby. First then the Keyfile is written out of the RAM into the Flash.
Attention! After the store of new canal-Settings, the EmuKey-filed must become again high store. It one would be used then humane from version 0.9.9.1. Humane was adapted specially on the HoT-firmware and
transfers no more basis parameter.
Attention! Presently a card in the internal CAM vorhaneden must be always, that includes at least the
Karteninitalisierung. However also an official Irdeto can or Betacryptkarte used become, that is queried also in
the EMU-fashion to the decoding.
In the Emu-fashions, one arrives over the ToH-Config menu. Under "Preselect", following attitudes are
possible:
EMU-K (Emulator and card) : ---------------------------.
In this fashion, ECM/EMM go' s both at the EMU and at the card. The card receives only ECM/EMM' s that through that 2. Irdetokennung of the card determined
are.
EMU-S (Emulator and Sharingserver for PW) : ------------------------------------------ .
In this fashion, another Sharing-server is included in addition into the communication. The connection takes
place via the serial interface at the Humax.
Advance:
1St Vebinde Cardreader at the PC (z. B. COM1) and Humax at at COM2 2. start CardServer 3. Settings: Add Reader,
set IP 0.0.0.0 (for server and client at the same PC)
4Th start CardServer again 5. premiere-Smartcard put away and test CardServer-Window 6. starting of HSIC: adjust
server-ip (=127.0.0.1) tcp-port and com-port
7Th Reset embedded HUMAX-CAM (0-RCL)
EMU (pure EMU fashion) : -------------------. This fashion not yet is transferred. Here it should be once possible to
activate the EMU without the putting away of a card.
PMCT ----.
In the PMCT, the CAS-systems can serve should that of the EMU under EMU-K, EMU-S and EMU, registered become.
Simply so let.
Much joke wishes the HoT-team
שלמה רוזן
הודעות: 2621
הצטרף: 22 דצמבר 2003, 23:15
שליחה על ידי שלמה רוזן »
בקיצור m8 נסה לתרגם לנו את זה,נראה לי גרמני שניסה לכתוב באנגלית וקשה להבין.מה הקטע עם windows 2000
who dares wins
amego
הודעות: 456
הצטרף: 25 דצמבר 2003, 15:03
שליחה על ידי amego »
שלמה בקיצור אתה לא צריך את WCE
העדכון החדש תחת בדיקה
וזה הופך את הממיר למכשיר או דומה למכשיר בשם DREAM BOX לענין של שיתוף SHERING CARD
פותיח +SECA2 D
CONAX
שלמה רוזן
הודעות: 2621
חבל על הזמן.מתי נדע ??
who dares wins
m8m8
הודעות: 11160
מיקום: home
זה עובד
שליחה על ידי m8m8 »
המקלט זה עובד על יד אמולטור
פותח את
DIGITAL PLUS-19 E
ALL SYSTEM
CONAX - THOR 1 W
מה שחדש כרטיס שיטוף ליומקס עד עכשיו לא יצא
גירסה זו V 1.2
שלמה רוזן
הודעות: 2621
מתי נוכל להשתמש ??
who dares wins
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
אתה יכול להישתמש כבר עכשיו
amego
הודעות: 456
m8m8 תודה לך
שלמה הגרסה מעולה המכשיר עובד ללא כרטיס כלומר פותיח את התחנות ללא כרטיס (sec1 irdeto1 via1 )
שלמה רוזן
הודעות: 2621
מאין אני מוריד את התוכנה והאים אני יכול להשתמש ב-windows 98 ??
who dares wins
שלמה רוזן
הודעות: 2621
חברים הורדתי את התוכנה ליומקס אבל לא מצליח להפעיל ,זקוק לעזרה צעד אחר צעד
who dares wins
sateyes
הודעות: 677
הצטרף: 24 דצמבר 2003, 17:29
מיקום: עמקים
שליחה על ידי sateyes »
שלמה,
אתה יכול לעלות את הקובץ למדור הקבצים?
אני גם מעוניין לקבל עזרה לפאץ הזה.
|כן| |כן| |כן|
m8m8
הודעות: 11160
מיקום: home
לצורך ניסוי
שליחה על ידי m8m8 »
אם יש אפשרות
לערוך ניסוי דרך כרטיס שיטוף על חבילת נווה דרך HUMAX 5400
שלמה רוזן
הודעות: 2621
תעזור קודם להפעיל את הפאצ'
who dares wins
mr dish
הודעות: 1697
הצטרף: 27 דצמבר 2003, 17:09
שליחה על ידי mr dish »
כדי שגם אני אצליח להבין....האם יצרו אימולטור למכשיר לשש השיטות הישנות? בזה אין כבר חדשות כה מסעירות, לדעתי....אלא אם הצליחו לשתול גם פריצה למה שהתחדש בחודש האחרון! ???
100עכוז
sateyes
הודעות: 677
מיקום: עמקים
איפה אפשר להוריד את הפאץ
שלמה רוזן
הודעות: 2621
יוסקה נסה לקרוא ולהבין את ההודעה באנגלית למעלה,אני לא מצליח להבין את הוראות ההפעלה,אולי אתה תצליח.ואל תשכח להודיע.
who dares wins
