E-HC/bC = Incorrect header block (CRC-16)
The software seems damaged while you receive from web site or e-mail. Pls receive the software again and try to download.
E-dC = Incorrect data block (CRC-16)
E-Hn/bF = Invalid HDF version
This error can be occured when you attempt to download Non-Superset STB software to Superset or Vice-Versa. Pls check the STB model and the software.
E-Id = Invalid system ID
This error can be occured when you attempt to download F1 software to F1-CI. Pls check the STB model and the software.
E-AC = Incorrect application (CRC-32)
Download latest version of application S/W.
E-ut = UART RX/TX time out
There is communication problem between source and target.
1) Check whether the S/W is compressed or not and Check whether you use the proper download tool for the software.
2) Reduce the download speed and try to download again.
3) STB main power Off/On and try to download again.
4) Reset the PC and try to download again.
E-Ad = Invalid address
Humax made the HDF file with wrong address. Select a valid HDF version.
E-Ao = Invalid offset address for upload (Odd offset)
There was a mistake when HDF file was made from binary file. Select a valid HDF version.
E-Ft = Flash program time out
The flash memory in STB seems damaged. Pls try to download one more time. If you fail again, send back your humax to replace the flash memory device.
E-It/Et = EEPROM program time out
The EEPROM in STB seems damaged. Pls try to download one more time.
If you fail again, send back your humax to replace the EEPROM device.
E-FE = Fail compare after flash write
Flash memory is damaged. Return the main board (CPU Board).
E-HF = Invalid HDF Format
Humax made the hdf file with wrong version. Select a valid hdf version.
E-Fn = Invalid flash device
Flash memory is defective. Flash memory need to be changed , so return the Main Board.
E-AS = Incorrect application size
Check the software version and STB hardware specification.
Humax 5400Z, ToH3.3 HoT 3.4
Dreambox 7000s, Hydra Phoenix
Dragon CAM + MII
Wavefrontier T90, 4 LNB 0.3 dB
I have donated - Make sure you do ! Cool
Back to top
View user's profile Send private message
Display posts from previous:
Post new topic This topic is locked: you cannot edit posts or make replies. JKF InterSAT Forum Index -> Humax All times are
