card sharing of nagra aladin
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
ATTENTION: the necessary file Initcam. txt is for A02-Karten and possibly must be adapted! Actually the adaptation of coco of rich must to make around a S02 from that. TYPE: simply generate with program season_blocker and adapt a few!
Cardserver-client for Season verse. 1.0
Card server: the server the communication with the card receives by means of Programmer. Tested cards types (A02, F384Z). Actually all cards types should function however. In want at real objects, I was not able to test that and have not yet implements it at present. Requirement should exist report in addition please,
I become myself in addition aufraffen.
1) with card connection 2 receive be indicated) server starting (it all available IPS, select please the desired! That should be it!
To be able to receive Card client: around the communication with a CAM each inquiry of the CAMs correctly must be answered by the client. Although it
concerns in the Receivern BC suitable Receivern, the querying tlw are. different. This basic communication can (must) define each in the file initcam.
txt, must be defined in addition the ATR in this file:
The file intitcam. txt has following construction: ATR: 3B 9F 21 0E 49,52,44,45,54 4F 20,41,43,53,03,84,55 FF 80 6D
FCAM:01 02,02,03,00,00 3D TCAM:01 02,00,00,02,03,00,10,03,84,00,00,00,17,62,00,00,00,00,00,00,415554 9F
.......................... ..................... ............ Erkהrung: ATR = ATR FCAM = queries of the CAM TCAM =
answer for the CAM
Each FCAM-entry must have subsequent a TCAM entry. That ":" is also compelling! 7 bytes are minimal necessary, therefore tlw. also the Ceckbytes!!!
TYPE: simply generate one put-file with program season_blocker and adapt a few!
An example file lies for an A02-Karte in! 1) Connection with server 2 receive "log on" receive) 3) with Season-connection
General Features: server and client can be started at the same PC. Whether the server stands in the living room and is where the living room then in the end, remains leave you. But attention: it no encoding of the Packages was planned be sent many information of me deliberately in the opposite Plain!! There the server and the client independent of one another work is MIX theoretically an of
different cards types on server and client side no problem.
Zacky
הודעות: 4354
הצטרף: 22 דצמבר 2003, 20:05
שליחה על ידי Zacky »
M8M8
האם אתה מכיר מישהו שניסה את זה ??? בטוח עובד ???
m8m8
הודעות: 11160
מיקום: home
עובד 100 %
שליחה על ידי m8m8 »
דבר סיזון אוו דרך DEREMBOX
זאת השיטה החדשה של NAGRA A
