הגדרת עידן+ בממיר 800se עם DVB-T tuner.
Re: הגדרת עידן+ בממיר 800se עם DVB-T tuner.
קוד: בחירת הכל
</sat>
<sat flags="0" name="DVB-T ISRAEL" position="400">
<transponder fec_inner="0" frequency="1514000" inversion="1" modulation="0" polarization="2" symbol_rate="08000000" system="0" />
<transponder fec_inner="0" frequency="1538000" inversion="1" modulation="0" polarization="2" symbol_rate="08000000" system="0" />
</sat>
<sat flags="0" name="DVB-C Cable" position="500">
<transponder frequency="01102000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01434000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01442000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01458000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01466000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01482000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01490000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01498000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01522000" symbol_rate="06917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01530000" symbol_rate="06917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01538000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01546000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01554000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01562000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01570000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01578000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01586000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01594000" symbol_rate="06510000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01602000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01602000" symbol_rate="06917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01610000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01610000" symbol_rate="06917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01618000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01626000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01626000" symbol_rate="06917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01634000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01634000" symbol_rate="06917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01642000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01650000" symbol_rate="06890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01650000" symbol_rate="06917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
<transponder frequency="01000000" symbol_rate="06917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0" pilot="0" rolloff="0" />
</sat>
Fifa1111
- הודעות: 71
- הצטרף: 21 יוני 2013, 11:01
לי יש תוכן דומה של קובץ
ובסריקה הצלחתי למצוא רק 200 ערוצים ( ברוטו עם הרבה זבל)
וחסרים לי עוד הרבה
איך מתקדמים ?
וחסרים לי עוד הרבה
איך מתקדמים ?
תיקנתי לך:
קוד: בחירת הכל
<?xml version="1.0" encoding="iso-8859-1"?>
file generated on sunday, 14th of july 2013, 23:30:11 [GMT]
by online satellites.xml generator @ http://satellites-xml.eu
please let us know if you find any inconsistencies in this file
<satellites>
<sat name="DVB-C Cable" flags="0" position="630">
<transponder frequency="1102000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1306000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1346000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1434000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1442000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1458000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1466000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1482000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1490000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1498000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1522000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1530000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1538000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1546000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1554000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1562000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1570000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1578000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1586000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1594000" symbol_rate="6510000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1602000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1602000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1610000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1610000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1618000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1626000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1626000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1634000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1634000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1642000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1650000" symbol_rate="6890000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1650000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
<transponder frequency="1000000" symbol_rate="6917000" polarization="0" fec_inner="5" inversion="0" modulation="0" system="0"/>
</sat>
<sat name="DVB-T ISRAEL" flags="0" position="400">
<transponder frequency="1514000" symbol_rate="8000000" polarization="2" fec_inner="0" inversion="1" modulation="0" system="0"/>
<transponder frequency="1538000" symbol_rate="8000000" polarization="2" fec_inner="0" inversion="1" modulation="0" system="0"/>
</sat>
</satellites>
ori
- הודעות: 254
- הצטרף: 13 ינואר 2007, 10:20
גם אחרי שאני משנה את הקובץ לווינים ומבצע סריקה הוא לא מוצא לי כלום
אני אמור לחבר משהו אולי מאחורה?
