newcamd v6.10
yhaddad
הודעות: 1391
הצטרף: 12 מרץ 2004, 21:08
מיקום: מרכז
שליחה על ידי yhaddad »
יצא גירסה חדשה לאמולטור הכי שמיש מבחינת הפיצוחים ומבחינת השיתופים :)
all binaries: use libcamdio - check for config files, especially newcamd.conf,
a lot of the old options don't exist any longer
all binaries: support Triple-Dragon
cardserver/cardspider: improve ecm handling, on old versions it was possible
for one cardspider client to cause dropouts for all
others, when zapping very fast (each zap would have
sent a new ecm request to the cardspider network,
possibly blocking requests from others), now new
request are sent only after 3 seconds or after the last
request from the same client is answered, whatever event
occurs first
cardspider: increased the protocol version number, so that network admins can
force all participants to upgrade to the improved version
cardserver.dreamTriple: add powerup/powerdown modes for Triple Dragon, see
betad.dreamTriple: readme in the libcamdio/TripleDragon directory
betad: added NDS for Sky Italia and BSkyB
newcamd: changed the path for the scce directory from /var/scce to
/var/tuxbox/scce (/var/scce would be in the ram disk on Dreambox 7020)
added via2.4 algo
cardserver/Conax: fix handling of cards that have some maturity rating enabled,
cardserver still answers "Can't decode" on protected channels,
because there is no way for the user to enter the pin and send
this information back to cardserver, but contrary to the old
version, at least the card will continue to work now on all
unprotected channels after zapping over a protected channel
scce/ecmoverride: removed pmt pid from the config lines
scce/mappings: added mapping for Seca2 SCT
גרסה חדשה ועדכנית למטה
m8m8
הודעות: 11160
הצטרף: 23 דצמבר 2003, 10:35
מיקום: home
שליחה על ידי m8m8 »
newcamd 6.01
v6.01:
cardserver/cardspider/camdcmd: add swap services command
newcamd: polsat nagra rom 10 fix, delete old /var/tuxbox/scce/strom3.bin and
put /var/tuxbox/scce/strom.bin into your image (the file is modified)
newcamd: increase timeout value for getting control words, shouldn't logout
anymore from the server while recording, if the server manages to reset
the card, internal optimations in newcamd done for it, because the
timeout is now greater than the time between different ecms arriving
from satellite
will still logout from betad, if it doesn't manage to reset the card,
done to protect your card from damage!
newcamd: some other optimations
cardserver/viaccess: stop switching back and forth of current ident when EMMs
are blocked
Dreambox/libcamdio.so: added autodetection of the number of internal cardreaders
גרסה מעודכנת למטה
yhaddad
הודעות: 1391
מיקום: מרכז
יצאה גרסה חדשה :)
גרסה מעודכנת למטה
Hlias sat
הודעות: 588
הצטרף: 09 אפריל 2004, 20:53
מיקום: רמת-גן
שליחה על ידי Hlias sat »
מה סדר פעולות ההתקנה
FDL230
הודעות: 3239
הצטרף: 17 מאי 2005, 14:43
שליחה על ידי FDL230 »
קודם NEWCAM 6.1, אחרי זה הCONFIG של 6.0 ומעלה, ואז המפתחות
כמובן שאחרי שאתה מתקין הכל אתה מסיר את הNEWCAM הישן שלך...כניסה לDOWNLOAD AND INSTALL ואז DELETE
1.20-7E-1W-7W
1.20-->9E-4.8E-13E-16E-19.2E
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
newcamd v6.02
תמיכה בטקילות
גרסה מעודכנת למטה
הודעות: 30807
חחח - הם התעוררו לחיים?
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
כן הם בחיים
הודעות: 30807
גירסת עדכון ל 6.03
v6.03: newcamd: new feature "constant" control word
some channels (BISS encrypted for example) use always the same
control word, these can now be set /var/tuxbox/scce/constantcw
libcamdio.so for Dreambox: add a workaround for the "no picture after
newcamd restart" problem
ppua: new syntax for this keyfile, newcamd will convert old files
automatically
cardserver: add an "Auto-PIN" feature for Cryptoworks cards, new option
CARD_PIN in cardserv.cfg, please read the warning in
cardserv.cfg about what happens when you enter an incorrect
pin code
גרסה מעודכנת למטה
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
קונפיגורציה NEWCAMD 6.03
גרסה מעודכנת למטה
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
גירסת עידכון ל 7020
גרסה מעודכנת למטה
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
גירסה חדשה NEWCAMD 6.04
v6.04: cardserver: "Auto-PIN" for Conax cards
newcamd: Canal Digitaal code added, Motors TV and Mezzo only
newcamd: priority feature completely rewritten, needs changes in
config file /var/tuxbox/scce/priority
newcamd: Cabo AU fix
newcamd: fix a bug in the config file parser regarding CWS options
m8m8
הודעות: 11160
מיקום: home
שליחה על ידי m8m8 »
גירסה NEWCAMD 6.05
v6.05: cardserver: fix viaccess class entitlement dump
cardspider: fix a particular nasty bug, that occasionally caused control
words to by matched to a different ecm request than they
originated from, this might have caused occasional black
screens, emergency shutdown requests or in very rare
circumstances segfaults in cardspider (obviously they must
have been very rare, because noone ever complained about
them)
cardspider: changed strategy when local users access local cards through
spider, these will now be preferred using user id as the sort
*** and will be handled before any ecm requests coming from
external peers
cardspider: added ECM_RESEND feature, if after 3-4 seconds cardspider
hasn't received a response to an ecm request, it will repeat
the request to external peers, this is intended to smooth
over the unreliableness of the udp protocol, but it might
increase the data rate used, if you are concerned about this,
the old behaviour can be restored by setting ECM_RESEND = no
in cardspider.cfg
cardspider: update avoidDropoutsHowto.txt, this is REQUIRED READING if
you want to run a stable network
although, we have not increased the protocol version number in this
release of cardspider which would've made it incompatible with the older
versions, we ABSOLUTELY RECOMMEND to upgrade everyone in your network
immediately, especially because of the bug fix above
גרסה חדשה למטה
הודעות: 30807
Newcamd 6.06 upgrade
v6.06: newcamd: behaviour when requested to decrypt two channels at once changed
will now continue to decrypt the recorded channel instead of
starting to decrypt the new (2nd) channel
newcamd: fix swapped control words for MTV+VH1 ESP
newcamd: fix Cabo AU nagra1
newcamd: fix nagra2 ecm nano parser for Cabo
cardserver: err, changed something weeks ago, forgot what exactly
libcamdio.so.0: (Dreambox) tries to get current channel from
/tmp/.listen.camd.socket when first starting
this means newcamd starts to decrypt immediately
when started after enigma (or later restarted)
needs cvs image compiled Dec 26th, 2005 or later
Official release newcamd v6.06 upgrade
check recent.txt for answers to questions asked recently in forums
please use drivers and libs from the last full release 6.01
Some news services indicated the European Union thinking about forcing Pay-
TV providers to offer their services beyond national borders to anyone who wants
a subscription. We strongly support such a move and we pledge that the emu and
cardsharing facilities in newcamd would be discontinued if Pay-TV providers
would start to offer their services internationally under the same conditions
they offer it to national residents. In particular:
1. same choice and contents of all channel packages (no stripped-down
international subscriptions like Digiturk Euro).
2. same prices as for national customers
It was never the intention of the newcamd Team that people would use it to steal
the services of their national Pay-TV provider (or any other provider they could
officially subscribe to). If and when everyone would be able to officially
subscribe to any Pay-TV package he wants to, under the same conditions as
everyone else and regardless of where he lives, we would feel newcamd becoming
kind of obsolete. The only reason why we make newcamd support emu and card
sharing is to overcome this discrimination by Pay-TV providers to offer official
subscriptions to national residents only.
הודעות: 30807
Newcamd 6.07 upgrade
"fix" showing of "can't decode" message, we actually wanted to show it all the time in v6.06, because when there's no picture, the message don't hurt anybody, however, we didn't realize, people using ci cams in parallel to newcamd (we don't really donow why, using cardserver/betad would have many advantages over using a cam), anyway, OSD_TIMEOUT = 0 know suppresses all messages again, OSD_TIMEOUT = 1 will show "Can't decode" messages only, any value >1 will show all messages
הודעות: 30807
גרסה 6.08 מלאה
להתקנה ידנית עבור ג'מיני.
להעביר ל var/tmp ולהתקין ידנית דרך במסך הכחול
humax
הודעות: 574
הצטרף: 09 ינואר 2004, 21:59
שליחה על ידי humax »
NEW CAMD 6.09 N2 UPDATE
הודעות: 30807
גרסה חדשה - עידכון.
v6.10: cryptoworks emu
keys needed in keylist and for providers with superencryption in
rsakeylist
dmitrysh
הודעות: 632
הצטרף: 27 פברואר 2006, 13:04
שליחה על ידי dmitrysh »
מה צריך לעשות כדי לעדכן גירסה?
ברור שאת SCCE אני מעתיק ל VAR/SCCE בדרימבוקס.
אבל מה אני עושה עם שאר הקבצים newcamd.i386 , newcamd.ppc , newcamd.conf
הודעות: 30807
ה newcamd בנוי לכמה סוגי מכשירים. הסיומת ppc אומרת שזה למכשיר הדרים בוקס והסיומת i386 היא למכשיר שעובד עם מעבד אינטל.
ה conf הוא קובץ הקופיג שלו וצריך להימצא ב var/tuxbox/config/newcamd
