pgi 1.4 megalon
- mbd
- הודעות: 657
- הצטרף: 08 דצמבר 2009, 14:48
pgi 1.4 megalon
Change List for PGI 1.4
- New: new recordings list with many more rows, better layout and navigation, information about free HDD space
- New: new media player libraries that allow better media playback (recordings and media player)
- New: new navigation concept for recordings/video files playback using numeric keys:
0 - jump to the beginning
1/4/7 - jump back 1/5/10 minutes
3/6/9 - jump forward 1/5/10 minutes
2/5/8 - jump to 25% / 50% / 75% of the file
The time interval for 1,3,4,6,7,9 can be changed (see FFRW option pgi.conf below)
- New: enabled direct switching between favourite groups using yellow and blue buttons while in favourite channel list mode
- New: it is now possible to cycle through Aspect Ratio modes with one colour button (can be set via the web interface)
- New: EPG database can retain past events (10 hours back) which can be viewed in EPG list (see new PGI option)
- New: string matching in EPG database is now case insensitive for Latin and Cyrillic based characters (for searching EPG events)
- Fix: correct aspect ratio is set automatically during media files playback with media player
- Fix: cooling fan behaviour when resuming from standby has been fixed
- Fix: corrected behaviour that allowed accidental switching of parental locked channel when changing channels too quickly
- Fix: pressing the Recall button at least 3 times without opening the channel list caused problems in favourites navigation
- Fix: EPG background scanning time was reset to 0 if settings were saved without editing the time
- Fix: corrected some EPG storing behaviour which was affected by DST (Summer Time)
- Fix: channel scanning does not stop forever on some transponders during full scan of a satellite
- Fix: tuner signal is not "disappearing" after scanning a transponder on newly configured satellite (under certain conditions)
- Fix: multiple bugfixes for the satellites and transponders editing interface
- Fix: usb_modeswitch/scripting improvements for initialising already switched USB 3G modems
- Change: Persistent EPG database maximum size has been increased to 64MB (wasn't enough for some demanding users)
- Change: DEBUG option in pgi.conf has 3 values now: "yes", "no" and "max" (see pgi.conf options below)
- Update: busybox, sqlite, e2fsprogs, mc, usb_modeswitch, vsftpd, dropbear, freetype, iptables, transponder DB
- Files: included two Handbrake presets (*.plist) to convert almost any video file into an MKV that is fully compatible with the media player ( http://handbrake.fr )
https://rapidshare.com/#!download|179p3 ... CEF113|0|0
addon 1.2
https://rapidshare.com/#!download|92p8| ... 7D44F8|0|0
addon 1.2
- הודעות: 1000
- הצטרף: 12 מאי 2007, 21:51
- mbd
- הודעות: 657
Re: pgi 1.4 megalon
לא קיים CCCAM ל-CUBEREVO אם יש לך שיתוף CCCAM תישתמש ב-OSCAM
ב-PGI כבר מותקנת הגירסה האחרונה שנערכה במיוחד עבור PGI רק תעדכן את
הנתונים שלך [ושל השיתוף] בקבצים המתאימים.
- הודעות: 1000
Re: pgi 1.4 megalon
ראיתי פה ושם גרסאות בטה ל-CCAM, אז מדבריך אני מבין שלא היו מוצלחות.
תוכל להסביר או להפנות אותי לקישור המסביר כיצד מסבים הגדרות CCAM ל-OSCAM ? תודה רבה מראש.
- mbd
- הודעות: 657
Re: pgi 1.4 megalon
כל גירסאות ה-BETA הם מזויפות [בעצם MGCAMD פרוץ]
העליתי עבורך תוכנה שמשנה באופן אוטומטי CCCAM ל-OSCAM .
היא בעצם מאפשרת שינוי של כל שיתוף ל-OSCAM .
http://www.2shared.com/file/VNZIxxU1/Os ... 50118.html
- הודעות: 1000
- mbd
- הודעות: 657
Re: pgi 1.4 megalon
קרא את הקובץ שבקישור .
http://www.2shared.com/document/ol4tlKQ ... cccam.html
בקשר לתוכנה כשאתה פותח אותה סמן את אפשרות ה-FTP בחלונות מלא את השם
הסיסמה וה-IP סמן את חלונית ה-SMARTCARDS מלא את ה-C-LINE בחלונית ה-CCCAMD-REMOTE
סמן ACTIVATE בחלונית USER/CLIENTS בחלונית CONNECTIONS סמן CCCAMD-SERVER ואת גירסת
ה-CCCAM שאתה משתמש . בחלונית ה-MGCAMD סמן את USE CCCAMD PROTOCOL
כשגמרתה חזור להתחלה וסמן SAVE ותן לתוכנה להעביר ב-FTP לממיר.
אתחל את הממיר כנס ל-WEBIF וסמן את OSCAM בתור ברירת מחדל .
בהצלחה.
בהצלחה.
- הודעות: 1000
- הודעות: 2
- הצטרף: 30 אפריל 2012, 14:18
Re: pgi 1.4 megalon
אין לי יוטיוב איך אפשר להתקין
מי יכול לעזר אני רוצה למשך סרטים מהמחשב שמחובר לרשת דרך המימיר מעין סטרמיר
תודה לכול ההעוזרים
תודה לכול ההעוזרים
