VISIONET
- ebenshal
- הודעות: 1240
- הצטרף: 21 דצמבר 2004, 10:24
- ebenshal
- הודעות: 1240
- ebenshal
- הודעות: 1240
- ebenshal
- הודעות: 1240
החלפת שרת - הסבר וכלים:
1-boxloader
1.51 fullflash
3-rs232 nul cable
Now to get your receiver up and running
First step is to plug you box in and boot it up to you TV
Press menu on the remote control on and look to see if there is a sub menu number 6 named smartcard if there is emu is switched on if not then press 9999 and it will pop up at the bottom as option 6
To flash you receiver so you can change server follow these basic steps
1, turn on you receiver and put into standby mode
2, plug you 9 pin null modem lead from you receiver to your rs232 (com port) port on your pc or laptop
3,Load up box loader
4,Go to setup comm and choose you com port (usually com 1)
5, you should see a message saying connecting the connection established if not check you connections and com settings
6, once you have established a connection you need to load the version 1.51 full flash dump into where it says update boot loader
7, Then you will see the screen on the computer of the box loader will start moving, all so on
the stb on the channel you will see it counting to 100. When it has done. Wait for 30 sec as
the box needs do more you will see it count again and at the end you will see good in the
window of the stb.
8, Turn off the stb and close down box loader
9, set the box back up again to boot loader and re do what you have done from step 1 but this time choose to update software in box loader not boot loader it will go through the same process as b4 just leave it until it says good on the front screen of the receiver and you can turn off the receiver disconnect the 9 pin null modem lead and turn the receiver back on
Once all these steps have been followed you can then begin to set you box up with your preferred server and network settings
1, Turn your box on and go press menu
2,go to installations
3,go to factory default
4, press the yellow button on the remote control (A box will come on (Are you sure to backup your whole date))
5, move to ok and press ok
6, after 10 15 seconds a box will come up saying backup complete click ok
7, then move across to ok and click on ok
8, the receiver will the reboot and come back on
9, once back on press menu and go to options
10, in the options menu go to system information a box will come on the screen with various info about you receiver
11, while the info is showing press the info button on your remote control
12, a box will come on (Region Dialog Box)
13 you can then enter you specified region code
33ff for Europe
0dff for Middle East
1fff for North Africa
47ff for Australia
Remember though that for 33ff you only input 33 then choose ok and the ff will auto fill in for you
Once you have you sever set to what you want you need to set your antenna and network up...as follows
1,go to the menu and choose installations and select you antenna (I have mine set to normal but set it to whatever you set up is)
2, once set click ok
3,go to installations and select the sat you want and make sure you have a signal on the bars on the left then click exit
4,go to network set up
5,set it to auto detect and click ok the click on apply a box will come up about setting will apply after reboot click ok and the receiver will reboot and come back on this is also a good time to connect your pc to the receiver with a network/Ethernet cable
Once back on click the fn key on the remote and it should bring up a box with information on the top and weather on the bottom choose information and you should see your status and a ip address etc if not try rebooting your receiver again and also rebooting your modem/pc
And that should be it
Please note that to change the server again you will need to go through steps 1 13 again and then re set your antenna and network settings again
1-boxloader
1.51 fullflash
3-rs232 nul cable
window of the stb.
33ff for Europe
47ff for Australia
- miki1
- הודעות: 410
- הצטרף: 29 נובמבר 2004, 19:43
- מיקום: מרכז הארץ
ואם השרת אצלי מוגדר ועבד עד לפני יומיים לאיזה שרת אני יעבור ?
- ebenshal
- הודעות: 1240
השרת שאתה מחובר אליו (למיטב ידיעתי)
אם אין לך את האופציה להחליף שרת כברירת מחדל הוא 0DFF
לי לא ידוע על בעיות בשבוע ימים אחרונים אולי לא היה מחובר.
ע"מ לדעת לאיזה שרת אתה מחובר לחץ על כפתןר ה"FN"
לאחר מכן בחר "information"
בשורה התחתונה יופיע מצב חיפוש: success פירושו תקין
waiting או searching יש בעיה
יופיע שם גם שם השרת (מסתים בFF
שתי האותיות הראשונות קובעות את השרת (0D 33 34 FF וכן)
ארז
ארז
- miki1
- הודעות: 410
- מיקום: מרכז הארץ
ע"מ לדעת לאיזה שרת אתה מחובר לחץ על כפתןר ה"info"
לא הבנתי איך לקבל מצב "SUCCESS"
כפתור INFO נמצא, ומתקבלים 4 שורות:
satellite
transporder
service provider
pid
בלבד....
אני עדיין לא רואה שום ערוץ מרשימת ערוצים שיתופיים.
מבקש עזרתך
satellite
transporder
service provider
pid
בלבד....
מבקש עזרתך
- הודעות: 110
- הצטרף: 16 יוני 2005, 21:33
- ebenshal
- הודעות: 1240
