Orginal/CVS 56xx Image
yhaddad
הודעות: 1391
הצטרף: 12 מרץ 2004, 21:08
מיקום: מרכז
שליחה על ידי yhaddad »
* multichoice epg fix part2
* mpg/vob/pva skip back was to fast
* more complete list of transponders using two byte encoding ( UPC / Cyfra and other )
* webif 3.3.0: restart vlc when switching subchannels
* fix problem with non running clock in standby
* dont show png not found messages
* after zap the epgcache is now running static for 25 seconds.. this fix incomplete epg on ORF... (this is a workaround for the really broken EIT on the ORF transponder)
* fix "sometimes enigma is now more responding after change radio channel out of the servicelist"
enigma was hang in the read syscall ( read the epgcache message pipe ).. i really dont know why...
so i have changed the order of "show background picture" and "inform epgcache about the channelchange" .. now the problem is gone..
directly not the picture show has caused the problem a usleep at the same place has caused the same effects... very ugly..
* store content of epg on enigma shutdown to /hdd/epg.dat and reread it on enigma start
* change storage size check to 50MB instead of 150MB .. better for use with hdd sticks or Compact Flash..
dynamic freespace check
להורדה כאן
